Fly cutter design
  • #16
    Originally posted by darryl View Post
    Ok, you say arbor size .75- why not turn a matching taper on the square stock so it can be inserted directly into your spindle instead. Maybe I'm missing something-
    [snip]
    What you missed is what I didn't say 😁 My spindle takes a type Y double angle collet. They're small - the largest is 1/2" & the closing nut only has 0.580+- opening. So making the fly cutter arbor to fit the collet socket would gain very little.
    • #17
      Originally posted by BCRider View Post
      And the smaller swept diameter you are indicating with that point on the tool means that it'll be more in tune with the required 1/2" arbor. I'm seeing it end up at around a 2" swept diameter. So relatively small by most standards but in keeping with your limit on the shank diameter.
      yeah, it's in tune with the mill size itself: it's a Rusnok head, 1/4(!)hp.
      It does mean that you'll be rotating in the reverse direction. Not a big deal other than remembering to push the right button or flick the switch the right way.
      It does run both directions. But I'm thinking that I should do the mirror image, so that I can use a left-hand turning tool, as it's rarely used on the lathe.
      [snip]
      One other thing you might consider since you're limiting the diameter and shank size and thus working within the rigidity limits. If you swap your 1/2" square cutter for a 3/8sq that would also give you a beefier thin side due to the smaller cutter. And for the size of the sweep a 3/8, or even 1/4 square tool bit would be just fine.
      The tool that I am planning on using is an index holder, so I'm stuck with 1/2". (I've gotten to like not sharpening bits.)
      • #18
        Originally posted by BaronJ View Post
        Hi Guys,
        I posted my fly cutter design on here a little while ago !
        [snip]
        I was going to make a cutter whose cutting radius was adjustable. I just assumed that would be desirable. But is it?
        • #19
          The opposite of adjustable is rigid. In machining rigid is a desirable quality. Making a fly cutter is a basic, do it yourself home shop project. Even store bought ones can be had fairly inexpensively. I would prefer to have multiple rigid fly cutters in an assortment of sizes rather than one less rigid adjustable one.
          • #20
            If you have a fairly substantial milling machine and wanted a decent homemade flycutter does inertia or mass of the flycutter go anywhere into making a better flycutter. Would a bigger chunk of steel give a smoother cut by absorbing the interupted cut. In other words using lets say a chunk of steel of 250mm by 20 mm thick give a better finish than what bented showed on those t bar type black flycutters. ?
            Also if one staggered three hss cutters at different height would it help in taking deeper cuts?. In other words would you get a first cut, second cut and then final cut so there is less work done onr the final or longest protuding hss cutter?
            • #21
              Originally posted by Bented View Post
              The fly cutters that utilize cheap triangular positive rake inserts work a charm on light milling machines, either make one or buy one and you will not be disappointed.
              Similar to this
              http://www.kristitool.com/shop/b-52-fly-cutter/
              That is a little bit on the expensive side for a hobbyist tool !
              Best Regards:
              Baron J
              • #22
                Hi Bob, Using a 12 mm (1/2" inch") spindle won't make too much difference, I've seen and used much bigger fly cutters on 12 mm shafts. Thinking about it how many hole cutters only use 6 mm (1/4" inch) shafts. I've got a four inch one that is on a 1/4" inch shaft, mind you it is much less likely to bend with a symmetrical load on it.
                Best Regards:
                Baron J
                • #23
                  Hi Plunger, If you think about it the cutter that sticks out the most is going to do all the work ! Yes the mass of the disc does make a difference ! However I wouldn’t be using a 10" inch fly cutter !!!
                  Best Regards:
                  Baron J
                  • #24
                    I was trying to wrap my head around that. But if you make the longer cutter inboard of the outer cutter would it not then make a difference.
                    • #25
                      Yes it is, very...
                      • #26
                        Plunger you are correct.
                        John b. SW Chicago burbs.
                        • #27
                          Hi Guys,
                          I also posted a drawing, but don't seem to be able to locate it at the moment.
                          The shaft on this one is 20 mm and the disc is 20 mm thick. I'm using 1/4" square hss tool bits.
                          I Like that design, it looks like it cuts smoothly, and its easy to make.
                          • #28
                            How about a flycutter whose radius is 12/pi ? That way the SFM equals the RPM. I think that's what Paul Alciatore did on his.
                            • #29
                              I don’t think you need radial stagger. As table feeds each tip will “see” something to cut as it takes its turn in the cut.
                              Some insert face mills have a wiper insert that puts the finishing touch on the cut.
                              • #30
                                It depends upon what you are prepared to trade off ! Rigidity or swept area. Don't forget that you can always move the "Y" slide to get a wider cut.
                                Best Regards:
                                Baron J
