In the last few days, there's been talk of posting more projects, as well as milling on the lathe, so I thought I'd finally take the time to post this milling attachment (a.k.a. vertical slide). I don't have a mill yet, so this comes in handy for things I can't do on the shaper.
First, I saw our own Paul Alciatore's milling table and I knew I had to copy it. Photo #1 shows it in action. The drawback of course is you have to shim the workpiece to the correct height. The upside is it's quite rigid.
However, needing more versatility, I was intrigued by these two milling attachments: Photo #2 is from Popular Science Nov. 1941. Photo #3 is from Popular Mechanics Nov. 1951. (If anyone wants the links, let me know.) Now, I was pretty skeptical that these would work as intended, but I had some suitable material in the scrap bin and I needed an excuse to practice lapping a ~2" bore. With the exception of the table, these can be made entirely on the lathe, but I cheated and used the shaper to cut the keyway and square up the block that holds the vise.
Continued in next post...
