I'm starting a shop in the house I live in, moving away from dad's shop slowly. So I need three phase. And since I don't believe in anything small, my first three phase motor I moved in is the 10HP motor in my Daewoo lathe. It's a Y start, Delta run, so it's actually only ~7HP starting load, so the 15 HP idler should be plenty.
Dad already found me a 15 HP motor he got on a big compressor that had been dropped and he got for a screaming deal. It runs, just needs bearings, so I'm go to go there. All I need to do is build the actual converter. I should mention that the motor is a 200 volt motor, but it's apparently been running fine on 240V for years.
Dad went with the Fitch Williams design. It works well. I will too at least on the balancing and power factor correction caps. But I'm thinking of using a pony motor. Partly because I think it would be fun, and partly because I'm sure the start caps would be pretty expensive, and I'm sure the utilities would appreciate the lack of the power spike.
So what I was thinking was:
I'm curious to hear HSM's thoughts. Thanks!
- 1 to 2 horse 3450 RPM single phase motor. A dime a dozen, nobody wants 3450 motors. I've probably got 5. Even one one of those "5" HP harbor freight motors with the 1/2" shaft which is actually like 2.
- 12V ac clutch from a car. Local junkyard is bound to have plenty, it would just be a matter of finding one with the right shaft size and fighting it off the car.
- I have a 20:1 transformer, 53A. It's rated for 120V input, but I'm sure it would work for 240V input. It was free, I don't need it. So that gives me plenty of 12V power.
- Dad has a friend that scrapped out a basically a factory worth of electronics. He has a few semi trailers full. I can get pretty much any circuitry logic for free, but it's mostly 12V.
- Dad and I have a fair few contactors, but they are mostly 120V logic. I'm not afraid of 120 or 240V logic, I've already wired with it a plenty on the Sidney or Dad's RPC.
- I don't have a big enough contactor for this motor, but I'll need one regardless.
- So the idea is to have a completely dumb electronic logic circuit. With one button push the pony motor starts, spins up to full speed (potential relay?, timer?) fires the AC clutch, spins the big motor up to full speed, using a 2:1 pulley reduction and automotive belt. The AC clutch is the small pulley, I'd only need to build the big one. After the big motor is up to speed, the pony motor and clutch are both killed and just the big motor stays on.
