Originally posted by Sparky_NY
View Post
Originally posted by deltap
View Post
I won't be calling the PoCo. They would want an inspection, then the 1962 grandpa-modified wiring would have to be redone. And if I'm doing that, well I might as well petition for three phase from the street. I doubt they want me to have a machine shop at all in a residential area. Nope, nope, nope.
I would like to put the RPC outside eventually, so slipping belts by foot is no good there. Needs to be push button.
Originally posted by Ringo
View Post
I'm not sure about those phase converter kits. They seem too cheap. Doesn't seem like nearly enough run caps either. How does one even balance anything with 3 caps only? No PF correction caps either.
Originally posted by J Tiers
Originally posted by Mcgyver
View Post
Originally posted by Captain K
View Post
Originally posted by Tundra Twin Track
View Post
I do not know if the 120 Volt transformer will work, without eventual failure, on 240 VAC. If it was made with conservative specs, it may very well work forever. However, a transformer with a 120 VAC primary coil, which is then operated with 240 VAC, WILL NOT produce the rated Voltage at the secondary. Transformers work with a RATIO of turns, primary to secondary. So if you double the primary Voltage, YOU WILL ALSO DOUBLE THE SECONDARY VOLTAGE. So, instead of getting the 12 VAC that you expect you will actually get more like 24 VAC. And that doubling of the secondary Voltage will also DOUBLE the current any 12 VAC component that is operated with it. Some could even burn out immediately but others will suffer from excessive heat (see note below) and may eventually fail from that. You really need to match the ratings either by using the proper transformer, or the proper input Voltage, or the other components with the proper Voltage ratings.
I really don't care about the transformer. It it works, then great. If it somehow melts down in the 3 seconds I am running it (which will be very impressive, it's a good 20lbs, that's gonna take a lot current to smoke it in that time), then I'll regroup and try something else, and it will go to the scrap yard. Personally, I'll place my money on it working, since it came out of a 240V delta device. I can always yoink a xformer out of a battery charger and run it on one of the 120V legs. Of course then I need a neutral, but there is plenty of ways to skin this cat.
Originally posted by nickel-city-fab
View Post
Originally posted by lakeside53
View Post
I'll search for your schematic lakeside. I'll let you know if I can't find it.
