Originally posted by BCRider
View Post
Tiny Inline 4 Engine
Layed out the parts I had completed a few days ago to send a pic to a buddy. Since then I have made the air filter mount and the flywheel mount, and then a few other pulleys and pins that I havent taken any pics of.
My cnc mill spindle is powered by an old treadmill motor that I'm running reverse from the direction indicated on it. The brushes were out fairly quickly and I was getting lots of sparking. Last night i disassembled it all and set it up on the lathe to center drill the ends of the shaft, then i mounted it and turned the commutator down to bright copper. Then i made some brass shims and mounted new brushes. It's a lot quieter and cooler than before, and has no arcing at all anymore.
I tried engraving onto a piece of brass to make the pushrod cover, but I broke a few 1mm endmills in the process. I have a much better 1/16" endmill, so I switched to it and started cutting, but then the cheap import x-axis driver overheated and shut down, so it messed up the part for the third time.
Turns out the wiring for the driver cooling fans had come loose, so I fixed that and now maybe this evening I will get a chance to try cutting this again.Last edited by Dragons_fire; 04-29-2021, 07:05 PM.
