Last time I tried to thread something internally, every time the boring bar with the threading insert took a cut it would lift the saddle. This made it impossible to get a good internal thread.
I don't understand why it results in saddle lift, to my mind it should be pressing the saddle down just as when turning an outside diameter or doing external threading.
I also think it's probably not supposed to be able to lift at all, but it's there, you can lift the saddle a small amount before a stop prevents it going further. I wonder if when the lathe was new, this was precisely fitted so it would not lift? But does now. I've considered epoxying brass shims to the sliding area to prevent lift.
Though I don't think it ought to happen in the first place. Any ideas?
My lathe is a lot like a South Bend 9, modeled on that.
