Bevel gear cutter
  • Bevel gear cutter
    Anyone got an idea where I might buy a 10DP #6 14.5pa bevel gear cutter?
    Is this what you're looking for?
    https://www.kbctools.com/itemdetail/1-203-054-6
      There is instructions online for how to use an involute cutter to make bevel gears but using multiple passes.
        I have a 10dp #6 14.5 pa, but the tip of the cutter tooth is too wide for the root of the small end of the gear. Can you direct me to the online instructions?
          I have an involute cutter with these specs. I need a bevel gear cutter with these specs
            start with post 9
            https://www.homemodelenginemachinist...5/#post-343522
              thanks for the link. appears to be very useful
                no worries. thats one of the first ones that i found. Im starting a build of the Tiny Inline 4 engine by Kelly Kubischta, and while researching that, i came across a few different resources for cutting the bevel gears for it. I thought i had linked them so i could find it when i get to that point, but apparently i didnt, so i will be looking for that into later on as well.
