Bevel gear cutter
  • Dragons_fire
    no worries. thats one of the first ones that i found. Im starting a build of the Tiny Inline 4 engine by Kelly Kubischta, and while researching that, i came across a few different resources for cutting the bevel gears for it. I thought i had linked them so i could find it when i get to that point, but apparently i didnt, so i will be looking for that into later on as well.
  • dhansen
    Originally posted by Dragons_fire View Post
    thanks for the link. appears to be very useful
  • Dragons_fire
    Originally posted by dhansen View Post
    I have a 10dp #6 14.5 pa, but the tip of the cutter tooth is too wide for the root of the small end of the gear. Can you direct me to the online instructions?
    start with post 9
    https://www.homemodelenginemachinist...5/#post-343522
  • dhansen
    Originally posted by tom_d View Post
    Is this what you're looking for?
    https://www.kbctools.com/itemdetail/1-203-054-6
    I have an involute cutter with these specs. I need a bevel gear cutter with these specs
  • dhansen
    There is instructions online for how to use an involute cutter to make bevel gears but using multiple passes.
  • Dragons_fire
  • tom_d
    Anyone got an idea where I might buy a 10DP #6 14.5pa bevel gear cutter?
  • dhansen
    started a topic Bevel gear cutter
    Bevel gear cutter
