I no longer own a box & pan brake. I have friends that own such but none have deep enough fingers to fold up the box-like part I am making. The part is a dust collection chute for my surface grinder.
I recall a technique where a guy wanted to make a sturdy lathe pan. He cut out his profile with his plasma cutter (think it was 1/8" steel plate) and then made slitting cuts along the bend lines leaving only short tabs to actually bend. Then he was able to bend the sides up easily by hand. Welded, the end result was very cosmetically pleasing. I do own a plasma cutter but I quail at the thought of actually making several precision cuts like that. I think my cuts would be wobbly or that I'd go too far and cut my tabs.
If I were one of the new youtubers I'd just whip out my angle grinder with a cutoff wheel and zip out some perfect bend lines. Again, I don't think I have the chops to control the tool enough to make straight partial slit grinds.
I did consider drilling a bunch of 1/16" holes. I have an old Orbit 14" drill press which I've fitted with a DC motor. I can get its spindle going pretty fast. That method might work.
Or, I could get out my blacksmith's slitting chisel and carefully walk it along the bend lines. Might be easier to keep that straight if I clamped on a "fence".
The sheet metal I'm using is 16 gauge steel. If I could grind a single point tool that would actually scribe a deep line, that would work maybe. Not sure what topology that tool would be.
The best solution I have thought of is to have my buddy make the slitting cuts with his little waterjet machine. Only I seem to have worn out my welcome with him, or maybe he's spring skiing in Colorado or something - anyway, he's not answering my emails.
I have a friend who used a smallish vee cutter in a little horizontal mill to make precision folding grooves in brass sheet when he was making up some jewelry boxes. Maybe I could find an engraving bit or something and find a way to mill grooves using my knee mill (a BP clone).
Before I go start wrecking sheet metal pieces, can you think of any other ways to try?
If you're curious, here's my working drawing: http://nwnative.us/Grant/images/temp...tretchout3.pdf
Thanks! - metalmagpie
