Cobbling together a carbide grinder
  • Cobbling together a carbide grinder
    Not really any plans, just what I had and some image googling for a rough idea of what to aim for.
    A small single phase motor, put a switch on it and welded a mount for it. Then I made a grinder rest. It's not finished yet. I am not happy with the table design, thinking of adding another swivel link and getting it right under the table. The existing links will also be redone with a square nut that fits into the slot on the other side, so I only need to use the levers on one side.
    I want to be able to set the table to 25-30 degree angle against the diamond plate for when I sharpen a scraper for steel scraping.
    (I don't own a single counter sink bit!)
    I have two sets of CS bits plus a number of others not in sets. But I don't know if any of them would have worked at the bottom of that slot so a regular drill bit sharpened at the right angle may have been the only way to do that.
    Looks like a nice job but at least one rattle can of paint is called for.
      Or sand blasting, or cold blue
        And a wheel guard.
        'It may not always be the best policy to do what is best technically, but those responsible for policy can never form a right judgement without knowledge of what is right technically' - 'Dutch' Kindelberger
          i like to use these diamond discs in a percussion drill. the spring action helps keeeping a steady pressure and does away with runout. as to the table, i like it to keep fixed positions, either by using angled pieces of wood or fixed spacers on an adjustable table. i find this essential for regrinding tools.
