Just started getting into the new money pit that is compressed air. Before anyone says it, yes it's mainly due to jealousy....I'm sure you understand!
I could do with a sanity check on fitting threads please - to know how tight it's supposed to be or if I just have naff fittings.
I'm mainly using BSPP and BSPT threads - knowing which it's going to be before you receive them is just guesswork. I do have one NTP thread and have ordered a separate fitting for that.
I know the basics of the thread form and the idea of tapers and teflon tape but I've not had to seal anything without o-rings previously.....and then only up to about 7 or 8 whole psi!
Fogbuster kit went together very nicely and no leaks on anything - but that only needs to go as high as 30psi.
I made up a main line to go from my (teeny) compressor to where I want to use things. Barbed end with a single-ear clamp was perfect straight away. The other end was a male 1/4 BSPT which I taped and screwed on a female 1/4" BSPT fitting. To get it sealed up to about 100psi (max pressure) I needed to re-tape it from 3 turns (as recommended on t'interweb) to 5 turns and also tighten it about as tight as I could get it with a pair of spanners. 3 turns of tape and tight weren't enough - neither were 4.
So, question is simply: does it normally need to be bust-a-nut tight with that many turns of tape or do I just have the quality of fittings I deserve for the money I paid?
I know it doesn't need to be pushing the max pressure and I expect I'll be running it at more like 60 for the main line and then drop it down from a wall block to each tool. That said, I wanted to know that my connections were good for the max pressure they could see.
