With a BS in Mechanical Engineering. No retirement for me yet! :P I start my first full time job at a defense contractor in a little under two weeks. Wish me luck!
I Graduated
No need for luck. Most engineering jobs are massively over-specified and over hyped to get people in who actually have a brain cell. You were probably the only applicant who actually knew what a lathe was let alone had used one, not that it is important as defence work is all about the paperwork. I did 20 years in Defence work where 100 off over 3 years was a massive order then to commercial where 10,000 units a shift was a slow day.
- Likes 1
Originally posted by Dave C View PostCongrats! I know you are glad to have that process over and done with. Good luck with the new job.
Originally posted by Doozer View PostGive yourself a graduation present.
An HBM, radial drill, turret lathe, and an upright drill
sound like a good place to start giving.
Originally posted by Baz View PostNo need for luck. Most engineering jobs are massively over-specified and over hyped to get people in who actually have a brain cell. You were probably the only applicant who actually knew what a lathe was let alone had used one, not that it is important as defence work is all about the paperwork. I did 20 years in Defence work where 100 off over 3 years was a massive order then to commercial where 10,000 units a shift was a slow day.
woohoo, congratulations! Definitely worth a pat on the back. Keep in touch with your old profs too, not only do they like hearing success stories but you're also a valuable contact and source of information/ advice for future students. I'm still in touch with one of my undergrad researchers who I worked with in 2016 and recently helped contribute to her getting a job, and I'm still occasionally in contact with my PhD supervisor even though I finished that part of my life nearly 20 years ago (oof, that makes me feel old).
Keep your eyes and ears open for future opportunities to gain other qualifications, like a Masters, especially if you can do one through your employer. They like having more qualified staff and you get paid more/ put on a better promotion track.
Very good!!!!
Now get that PE as soon as you can. I assume you took the test already (I didn't bother, which may have saved me from a boring career designing substations for the Powerco!) The PE is optional, and I know a lot of folks who do not bother. In fact, most of my employers did not want a PE.
But it opens options, which is more important now than it was in the past. Back then I could "walk down the street" and get another engineering job, but that probably is not the case any more, different environment, changing fast.CNC machines only go through the motions
