Hello Gurus. Years ago there was a discussion here on making a toolholder in a solid rod so it could hold a carbide tipped lathe bit. The stock for making the square hole in the rod was called something i can't remember and the place it was available has also escaped me. So basically i want to weld in the rod into a hole drilled into the 1" solid rod and insert a bit to clean up a thrust bearing surface on a engine block. Kind of feel like i handed you guys a puzzle
Hydro
