First post on here. Run my own shop making parts. Have a Milltronics VM4222IL, and just got this lathe. Have plenty of other machines only geared toward engine maching. Need help with a new lathe that we are adding a VFD to allow soft start, variable speed and to run on single phase. The lathe is a Hwacheon HL-460. The VFD is now wired in and uses most of the factory control circuits.
There is
Forward/ Reverse control from hand levers
Brake stops the motor
Off/On switch works
Open door switch
E stop
Here is the problem. When stopping with the hand levers, the spindle coasts to a stop as we wanted to. When using the foot brake, the spindle will stop, but once releasing the foot brake, the spindle starts again.
The control is using the For/ Rev option with continuously maintained switches from the levers. If using 3 wire control, the VFD needs push button signals for for/ rev. But the switches are maintained in this machine. Is there a switch that will bolt into the same location and be a pulsed output.
Any other ideas?
VFD is a FUJI 20HP mini unit. We have added a potentiometer for speed control. This lets us run the lathe between 50 -100% of spindle speed in each gear.
There is
Off/On switch works
Open door switch
E stop
Any other ideas?
