I can think of lots of slow labor intensive ways to do this, like using my air nibbler and then a die grinder with a large diameter stone, or making a tram with a cutter on the end and draw it around and around till I'm through. Any good ideas?
FWIW, this is but step one in another stupid idea to get somewhere. I want to make a very shallow bowl of 1/16" thermoplastic 11" dia with a radius of 70". This round cut in steel is to make a frame for the vacuuformer plate to see if I could control the droop from heat well enough to get close to my 7/32" target.
