thought I'd post this up as a little project. Installing a DRO was pretty much the last major thing on the list before putting my wide 9 back together, so I'm pretty pleased to get it done. What a faff that was, more drilling, tapping and head scratching than I care to remember.
Had to cut the cross slide scale due to some mixed up communication, but that went fine with an angle grinder and a thin cut off disk. Tapping 4 2-56 holes in the end was a pain
the cross slide was the biggest pain. Had to countersink the way cover so I could screw it to the cross slide (had these weird "pins" before), then attach an arm to hold the read head out behind the lathe. Scale is bolted directly to the piece that attaches to the saddle plus a 3/8x3/4" bar that is also attached to that piece. It's pretty sturdy.
Finished it off with a cover for the bottom and a piece of treadmill belt to cover the slot at the top
Carriage scale was alot less of a pain, with a block that bolts to the saddle piece and a plate that connects that to the read head. I used 2 5/16" thick pieces of alu at each end of the scale to attach it to the bed as the side of the bed had a 1deg or so slope off vertical.
whole thing
whole thing
