First of all, I'm no sparky so go easy... I've been trying to determine how to power this thing with minimal expense. I have another lathe that does most of what I need. This one would see only occasional use when I need the larger size.
I just acquired a 1960s vintage lathe with a 5.5kw 3 phase drive motor. Currently wired 440. Motor says 220/440 on the tag. I have plenty of 240 single phase available.
I have a 5hp idler motor and static converter on hand. Do you think I could start this lathe with a 5hp 3 phase idler and a static converter? I cannot imagine needing the full 5.5kw of the lathe motor. Possibly need to adjust something with the motor starter or overload heaters, not sure. I'm content to have less power available as long as I can start it.
I have wired up VFDs and feel comfortable with that but I really don't want to risk a cheap vfd. Automation Direct I'm looking at $1000+ for a vfd. Ouch.
A commercial rotary converter and step up transformer would do this job with zero modifications I believe. But that's going to cost $1000+ too.
I really don't want to swap motors in the lathe but that is a possibility.
Looking for suggestions! What would you do?
