[QUOTE=strokersix;n1943889]Motor data plate on this lathe: Anything jump out as a problem? I'm curious why the amp rating isn't exactly half for 440v. Also noted 1165 rpm................../QUOTE]
Take a look at the power factor. It is higher for the lower voltage, so the difference in current is accounted for by that. (listed as "Cos" with the Greek theta). Lower power factor is more current
