I see those drop In welding clamps. Does anyone know what the tolerances are for the hole and the clamp. Thanks John b.
Welding clamps
Originally posted by john b View PostI see those drop In welding clamps. Does anyone know what the tolerances are for the hole and the clamp. Thanks John b.-paul
Arcane,
I think he's talking about these type of things: https://www.gereedschappro.nl/artike...BoCkIwQAvD_BwE
IanAll of the gear, no idea...
I don't think the style already mention will work for your design. We had this type at the last place I worked at: https://buildprotables.com/
IanLocation: Saskatoon, Saskatchewan, Canada
Look at how hold fasts in an anvil work. They can be pretty sloppy but still hold well. The issue becomes that if they are too sloppy the clamp will tilt too much. But you don't want the fit to be so fine that a touch of spatter or grinder grit causes things to jam.
What I'm thinking is make the plug on the end with a fairly loose fit in the hole. Like up around .03 of play. That should be enough to avoid the odd bit of spatter and grinder grit from causing any issues. But then join the plug to the clamp at an angle so when the plug is cocked to the locking angle in the hole that the clamp is properly vertical. Or if making your own clamps instead of the sliding arm go with a bent piece of rod shaped like a "7" so the horizontal part is parallel to the table at the locking angle and drill and thread the end of the 7's top arm for the clamping screw....
Or dare I suggest just making them as a hit down to lock and hit the back to release like a traditional hold fast? If you go that route they are super easy to make and use. So you can have lots of them. And they are neatly low in profile since there are no tall fixed length pillars or sliding arms with screw handles.
As for the sockets. If you use a solid top then I'm thinking it needs to be quite thick to avoid damage when the plug pries against the edges of the holes. And that seems to be supported by the 5/8" metal "planks" used by Build Pro. For a home shop situation though I'd think that one could get by with 1/2" and use a little consideration with the clamping pressures.Chilliwack BC, Canada
Originally posted by BCRider View PostLook at how hold fasts in an anvil work. They can be pretty sloppy but still hold well. The issue becomes that if they are too sloppy the clamp will tilt too much. But you don't want the fit to be so fine that a touch of spatter or grinder grit causes things to jam.
He desires to make clamps and bases similar to the ProTables ones that will work with the grating.
Originally posted by reggie_obe View Post
I think you've missed the point........
Originally posted by john b View PostThe part that goes in the table will not be wielded in . It will be able to twist lock any place I want to to put it.
- Likes 1
