From reading another thread, some suggested an 'impact screwdriver", I thought of making a hammer-activated impact screwdriver. I have lathe, mill, etc., but no plans for its' design. Can anybody share design/build plans?
Make an impact screwdriver?
Years ago I had a hammer smacked impact screwdriver. At one point I took it apart. It was sort of like this sketch. The pin and the hole allowed for about a 90 movement. To use it you hold the outer barrel (not shown) with some twist to it like you would use if loosening the offending screw. This causes the blue pin which is held in the outer barrel to ramp up the sides of the V shape. Then give the outer barrel a whack on the end. The pin is driven forward against the ramped sides which pushes the center body forward and torques it sharply. This sketch is actually not TOO far out of scale for the size of the notch. Although I'd form the corners to be the same radius as the pin to better let the inner piece withstand the impact forces. The ramps can actually be quite short just as shown. After all you're just trying to break the thing free. So once the original grip is broken... or the head snaps off... it should come out more easily with a regular driver.
Making one isn't going to be easy. For starters the whole inner body and hex socket on the end needs to be heat treated to harden then temper it back to a tough violet bordering on blue temper. And you'll want to get a source for sturdy impact resistant hex bits as well.Chilliwack BC, Canada
Originally posted by Bented View PostThe lowest cost method of producing such a device is to drive to Lowe's and buy several for $16.00 each.
https://www.lowes.com/pd/Kobalt-Impa...-Set/999957785Chilliwack BC, Canada
Originally posted by boslab View PostWonder if there’s a smaller impact sausage, like 1/4 bit size, some electrical screws are buggers to shift
markChilliwack BC, Canada
Originally posted by boslab View PostWhat I was thinking ( hard these days!) was a screwdriver/ automatic centre punch hybrid, probably best left in my imagination I suppose
mark
The impact action of an auto center punch is pretty well documented on YT and other sites on the web... and in some older books too I'm sure.
Seems like it should be not too hard to put in the same idea of a V and pin or two V's that fit and ramp up each other. Twist to determine the direction then push to load then release the impact.Chilliwack BC, Canada
- Likes 1
I have several styles and sizes of hand held hammer impact drivers, my oldest Vessel is still going strong after many decades and has saved the bacon more than I care to remember.
This thread though is a reminder to build a shop built knock-off of an air hammer version. I used one like this a while ago at buddy's shop to remove some auto body door hings and it worked great. I've already aquired some HD impact duty slotted, Philips, and JIC bits, just need some elbow grease to seal the deal.
I need one!
Bad Decisions Make Good Stories
- Likes 2
mark
This is an Unicorn Impact Uni Driver. Includes Six Extra Long Bits. Buy In Bulk.We have tons of parts available!
- Likes 1
