Finished putting together my South Bend wide (heavy?) 9
  • #16
    Looks like Luke Skywalker is slowly becoming Darth Vader.
    -D
    DZER
    • #17
      Originally posted by AZHTR View Post
      Yes that is amazing. I read this forum a lot and I have to say the majority of you guys do incredible work/projectsđź‘Ť
      thanks, that's much appreciated. There's some selective bias though - you don't get to see my screwups
      -D
      I can feel the pully of the Dark Side, it is futile to resist!
      • #18
        finally finished up a new countershaft and motor pulley so I could use a wider poly V belt (J8 instead of J6) to both slow down the countershaft a touch and reduce belt slip
        the main part of the pulley was a piece of 6" round I got in trade bored out to accept the hub, which was then pressed and dutch keyed in place
        used a 1" annular cutter to remove some material
        blingtastic New motor pulley on right
ID:	1965369Click image for larger version
        the static balanced on my ghetto rig
        I had to extend the motor mounting bolt slots in the motor plate to get sufficient tension with the new belt, which was a complete PITA. 2 hours disassembly and reassembly with 10min of machining in between.
        Works well though and has dropped the spindle speed for the same speed pot position by 20%. Still get a bit of slip in direct drive at low motor speeds/ high load, but it's better and it'll be even better once I finish up the 3 step countershaft pulley
        • #19
          Originally posted by Stu View Post
          Nice, I like the variable speed control setup. It could be the angle of the picture, but the DRO seems like a far reach.
          Stu
          So apparently I didn't notice the thread first time around so I've deleted what I posted.
          So how is the DRO working out where it is? It looks like it's in the spray zone for oil off the chuck. Or did you end up moving it? The pictures make it look like it's right in the path of the chuck's oil spray and could possibly also be whacked by any balls of swarf that were to get picked up and thrown by the chuck jaws.
          The new countershaft pulleys look fantastic. And since I missed the thread earlier the restored lathe also looks fantastic.
          Chilliwack BC, Canada
          • #20
            thanks! It's all working out pretty peachy The DRO readout is about 4-5" to the right of the spray zone - I know that as I can take a ruler and measure from the side of the DRO to the long vertical stripe of oil on my pegboard It's a good reach for me and I can use the controls without extending my upper body over the lathe. I'm pretty tall and everything is set up just right for me. If someone below 5'6" tried to use it they'd probably struggle a bit. The readout doesn't really get hit by swarf much. The occasional alu chip makes it up that high, but most of the mess hits the backsplash with a little hitting the holders.
            I'm really pumped with this lathe. Still have a few projects - countershaft step pulley, threading dial, extended tailstock and new backplate for an adjust-tru chuck - but it's very useable as is.
            • #21
              Your pulley looks great!
              Jerry
              • #22
                thanks Jerry! It's also almost completely hidden behind the lathe My friend told me it would look great anodised and attached to a nice big blower on top of a V8
                • #23
                  Matt, that is a gorgeous pulley. I am impressed. Also, nice 4 jaw.
                  • #24
                    thanks man, that's very kind! I forgot that I hadn't sent a pic of your old 4 jaw in action I still need to make a new screw for it, but I have to make a threading dial first..
                    • #25
                      Wow, nice job! It's ready for another 50 years of work!
                      • #26
                        thanks, it's getting there. It's a real pleasure to use too, which is a big plus
                        • #27
                          Are you gonna be able to get the RPM's down in case you ever need to? I don't recall seeing any back gear? (the range on mine is from 50 to 1200 -- but the extra torque comes in real handy sometimes.) Sometimes its easier to go slower when threading a short section etc.
                          • #28
                            absolutely! Back gear is there and I use it for higher cutting force/ low speed stuff as the belt will still slip a bit on the motor pulley. Stuff like grooving the poly V pulley. Speed can go down to pretty much 1rpm with back gears When I get the 3 step countershaft pulley made I probably won't use the backgear as much as I'll be able to get much lower speeds direct drive and still be in the motor sweet spot.
                            • #29
                              You do very nice work, to be commended well recovered machine, well done also very nice pulley
                              mark
                              • #30
                                thank you Mark, that's very kind
