Doall: Well Named
  • Doall: Well Named
    Nothing fancy or high-tec just needed to notch a 1-1/4 NC Nut to go on elevating pad,was going to mill it but ended just doing in my Doall Vertical Bandsaw.Very handy and gets used lots. Click image for larger version
ID:	1946121 Click image for larger version
ID:	1946123 Click image for larger version
    I have a 9" bandsaw rebuild on the back burner that is a Du-More
      Gotta show off your nuts eye sea. LOL
      -D
      DZER
        I'm seeing end mill marks on the nut. What part did you do on the bandsaw?
          I see multiple lines of tooth marks, much as you would see cutting a dado or rabbit with a single blade.
          The drill press vise, a Heinrich?
            The Nut had no contact with a Endmill those are Bandsaw Blade Marks,the reason I posted was to show the Versatility of the DoAll Machines.
              Circular feature telegraphs a moiré pattern through the blade.
              -D
              DZER
                Thats a hell of a good sawing job ! I would love to see just how you did it to get it that nice.
                I have a 16" DoAll and agree, its a extremely handy and versatile tool. I use mine more than I ever dreamed I would.
                  Just get the guides and the bearings set right and giddy up.
                  I have a 1612 Doall at home and at work.
                  I make assembly cut-aways and it is awesome for that.
                  -D
                  DZER
                    Yes a Heinrich 30 with some upgrades it came with a sliding handle like a typical bench vise,added a Tri Ball handle for speed with Hex incorporated into hub if need extra tightening.I went with this 8” style as it’s opening is just over 10” and was a little cheaper than there quick action models.I am very pleased with this design and would want no other,Heinrich Rep said this particular design is older than dirt.🙂 Click image for larger version
                      Thanks Sparky,I cut the solid lines first then the curved dotted line second and other dotted line last.In the background is the remains of chunks from Nut.I can never say enough about these Saws,it’s the most used Machine I own 1950 ML 16. Click image for larger version
ID:	1946295 Click image for larger version
                        It’s my only claim to fame, actually cutting a meteorite on a do all saw, it was to etch out the beautiful widmanstatten structures present, it was a fairly big slice,
                        hard to get your head round somthing that came from who knows where in the galaxy having the right blade speed on a big ol bandsaw
                        mark
