We all know that cutting metals can leave rough edges. Some metals will always be drawn away from the exiting edge of the cut forming a ragged extended ribbon that has to be removed. This even happens to some extent with harder metals, probably due to high temperatures causing the metal to flow. So, we need to de-burr after making most cuts.
I often use a file to remove these burrs from freshly cut parts. Last night I was cutting some aluminum brackets for an electronic project. They were simple 1" x 1" x 1/4" blocks of an unknown aluminum alloy that I found in my scrap box. It was a somewhat harder alloy, perhaps 6061-T6. But when I milled it to size, the cutter left burrs on the edges and I grabbed a fine tooth file and proceeded to remove the burrs. This worked well on the 1" edges where I could easily file a nice, uniform 45° chamfer. But I have always found it more difficult to use a file or even a piece of fine sandpaper on a flat surface to de-burr the shorter edges like the 1/4" ones on these simple blocks. Often I will think I am holding the file or the part at the proper angle but when I look at the result, I find that one end of the edge has too much metal removed while the other end still has the burr present. So I have to go at it again.
I have purchased and tried some of those nifty Noga deburring tools, but they must be used twice on an edge in opposite directions to get both ends. So the middle get cut twice and has a larger chamfer than the edges. And you can leave one or two divots at the two starting places. I find I like using them most for deburring holes and curved edges, not straight ones.
I know this is not a real big deal, but I just started to wonder if there might be a better way to do this. And I know there are machines that make this an easy process, but I have neither the time, nor the money to buy or make one and even if I did, there is no place to put it in my overcrowded shop. Being a bit of a proud craftsman, I would like to make nice looking parts; as nice looking as I can, anyway.
Any thoughts? What do you do to de-burr a short edge?
