Originally posted by Doozer
View Post
More Estate Sale Machinist Crap
- Likes 1
Back in the Apr-May 2020 Machinist's Workshop I had an article, "Easy Mill Vise Alignment". It details my favorite method of aligning the mill's vise. It uses two DTIs, one on a magnetic base on the table and the other in or attached to the quill or head. It saves most of the back and forth motions of the table. For +/-0.001" you can just move once and a second trip back and forth improves that number to about as good as your mill and vise will allow.
Basically you zero the two DTIs on one side of the fixed vise jaw and then move the table so they are on opposite sides. Then you just MATCH the dial readings and you're done. No particular dial reading is needed, just MATCHING readings. A trip back and forth would mostly be to be sure that nothing moved. For maximum accuracy you should lock all movements at each table position.
This method was inspired by those fancy and expensive devices that sit over the mill's vise and use two DTIs.
https://www.shars.com/vise-square
It uses the same, two indicator method without the expensive device to hold one of them. And it is easier and faster to set-up.
Originally posted by Mcgyver View Post
I don't think Doozer is a professional machinist either. Niether am I, and like him I don't own any device to make tramming easier, but like you don't get the vehemence against them.
Perhaps its religious?Paul A.
I always find it perplexing the lengths guys will go through to get around having to re-tram a vise.
Totally ridiculous. It's not that hard.
-DLast edited by Fasttrack; 06-19-2021, 12:43 PM.
