I need to cut a few 2 7/16" diameter glass circles. Thickness is approximately 2mm. The circle cutter I have won't go that small and can't be modified. Does anyone have actual experience cutting glass circles that small? I've seen a couple advertised on Amazon and eBay but I'm looking for someone that has a cutter that goes that small. What are you using IF you've cut glass circles this size or smaller?
-JW:
-JW:
