Originally posted by alanganes
View Post
Cutting small glass circles
Thanks to Post #21 we know now that you're after a half dozen or so. And have no shop.
That pretty well narrows it down to either having a glass shop cut them for you, buying a circle cutter that can do smaller circles or as epicfail suggests bodging up cutter of your own in some way.
For something this temporary could you use just the beam and cutting point from the circle cutter you have now and bodge up a second smaller center pivot? Used with a bit of care I'm thinking that instead of the usual suction cup you might get away with just a block style pivoting base which you hold down with a piece of that non-skid shelf matting. Yes it would be a touch clumsy and need a bit of care. But it has the potential of being doable with very simple tools which you probably have on hand.Chilliwack BC, Canada
Click on this guy. https://www.ebay.com/itm/26411494699...0AAOSwmmxW2y6s
For the few pieces you need it's not worth dicking around to make them.
- Likes 2
I once watched a guy cut a circle out of the plate glass window which he was replacing. The cutout allowed him to reach through and open the door from the inside. This was about a three second operation. First the suction cup to attach a handle, next the 360 degree sweep to scribe, then the single tap to knock the piece out. Since I questioned him about it, he told me that the secret was to make only one quick sweep with the cutter, with enough pressure to score deeply enough the first time, then don't wait before knocking it out.
The window had been shot, and besides the bullet hole it had a few cracks going to the edge of the glass. To me that would have been a dangerous operation. He made it look like childs play. The only point I'm making is that glass is easy to cut if you do it right.
I'm thinking that for you, the hardest part is arranging to swing the scriber in a circle of desired diameter. How you do that the glass doesn't care. How rigidly you can perform this operation- the glass does care.I seldom do anything within the scope of logical reason and calculated cost/benefit, etc- I'm following my passion-
Originally posted by darryl View PostI once watched a guy cut a circle out of the plate glass window which he was replacing. The cutout allowed him to reach through and open the door from the inside. This was about a three second operation. First the suction cup to attach a handle, next the 360 degree sweep to scribe, then the single tap to knock the piece out. Since I questioned him about it, he told me that the secret was to make only one quick sweep with the cutter, with enough pressure to score deeply enough the first time, then don't wait before knocking it out.
"Get it while it's hot" is the glass cutter's theme.
one clean scribe does it, and a ready supply of fresh sharp wheels answers that need.
The only addition is to dip the wheel in kerosene just before making the cut. The lamp oil lubricates the wheel axle, and spreads to the newly created fracture line to prevent "healing" , where by the glass will actually meld it's self back together. (Back to the "get it while it's hot" theme.)
The issue I see with the OP's application, is the small size of the desired part. It is very difficult to manipulate the scribe tool to achieve one good line in such a tight radius.
One idea would be to produce a template in durable material, cut glass octagons. affix the template to the glass blanks, and then wet sand the blanks using SiC paper .
Tedious , but the OP has no tools... hand work is all that remains.
I've done similar , but made use of a 10 inch diamond wheel, a lathe, and an oil coolant pump. Not really a "I've got no tools" solution. ;-)Last edited by CalM; 06-23-2021, 11:23 PM.
Something that occurs to me is that stained glass makers have been cutting curves for a long time with minimal tools. Sometimes working in one big piece and sometimes making radial scores to break away the waste in little segments.
Again YT has lots of videos on "stained glass curves" but here's one where he is almost cutting a full circle with very minimal tools.
(12) Stained Glass Crescent MOON - Cutting Curves Freehand - YouTubeChilliwack BC, Canada
Originally posted by I make chips View PostClick on this guy. https://www.ebay.com/itm/26411494699...0AAOSwmmxW2y6s
-JW:
I was successful in cutting a few discs. They actually turned out very nice.
https://www.youtube.com/watch?v=H7k41380Imo
-JW:
- Likes 2
