I have just finished bringing a power hacksaw back to life. There is no relieving device for the pressure on the blade, The crankshaft revolves in an anti clockwise direction when I stand facing the crank side of the machine, The blade which was in the machine was arranged to cut on the pull stroke. Is this correct? Regards David Powell.
Which way should the blade face?
Originally posted by projectnut View PostYou don't mention the brand or model saw. As previously mentioned the vast majority of power hacksaws do cut on the pull or back stroke. Having said that there are a few that cut on the forward or push stroke. Knowing the brand and model would certainly help in this situation.
Brand does not matter.
-DDZER
- Likes 2
The machine was made by the Perfect Machine Company, Galt , Ontario, before 1923 when they went broke. The nearest similar, but not identical machine is a Sterling, seen in a Youtube video. Perhaps a case of plagiarism, or licensing. Now.with a few repairs it cuts straight and runs very quietly. Regards David Powell.
Fact of physics that it is better to absorb the forces into the fixed and more rigid jaw.
-D
You sure about the no relief idea? I know that a lot of them don't SOUND like they relieve the pressure. But I do recall the couple I saw in my youth and videos on YT seem to confirm that most, if not all, have something that at least reduces the pressure.
That actually makes sense too. We want to relieve the pressure but we don't want to actually lift the blade and let it crash back down even a short way at the beginning of each stroke. That would tend to snap teeth off in short order.
Chilliwack BC, Canada
If you can; hold onto the end of the guide bar if it has one and run the saw. Can you feel an oscillation in the load your holding signifying a changing force on the blade? My power hack saw cuts on the push stroke and I have the manual that says so.
lg
no neat sig linenear Salem OR
Originally posted by larry_g View PostIf you can; hold onto the end of the guide bar if it has one and run the saw. Can you feel an oscillation in the load your holding signifying a changing force on the blade? My power hack saw cuts on the push stroke and I have the manual that says so.
lg
no neat sig lineChilliwack BC, Canada
-D
Large shapers also commonly cut against the movable jaw and were designed to do so, the brand of which does not matter.
- Likes 1
