small metric V-belt source
  • small metric V-belt source
    Where to find small metric sized V-belts?
    In this case for a Emco Maximat Standard mill head
    from the 1950's. (http://www.lathes.co.uk/emco/page9.html)
    Belts are: 8mm width, 5mm height, 450mm/630mm length
    They seem standard enough across the pond
    but not finding closer source or any that will ship
    to US west coast (so far).
    I do realize there is some flexibility in that
    they are all tapered sheaves with the same
    40-degree include angle but would like to
    give the machine the replacement part it was
    originally designed to work with if possible/reasonable.
    Tom C
    ... nice weather eh?
    Try beltpalace.com
    Graham O
      You might take a look at making your own belt using Polyurethane Belt material found on Amazon. I just ordered some of it to make a belt for a project I'm working on. You cut it to the length you need and weld it to a loop using heat. It's a simple process. Check it out.
      Oregon Coast
        You might try a brick and mortar bearing supply, I was trying to source a belt for a EMCO toolpost grinder ( 5x352mm )
        online and it was a waste of time since like you whatever source was in the UK.
        My local bearing supply house was able to source a belt for me ( it's 3mm longer )
        but that should work.
          Frankly I would check Amazon, they have had bearings my local supply house could not find. I am sure belts may be the same, who knows unless you try.
          Retired - Journeyman Refrigeration Pipefitter - Master Electrician - Fine Line Automation CNC 4x4 Router
            SPZ/XPZ is the smallest metric belt I can find, 9.5MM wide at the head, 8MM deep. No numbers on the original belts?
            Maybe it's not metric?
              A good bearing supplier should be able to help. In the UK, I looked at the "simply bearings" site and they stocked VB type belts which started at 5mm wide.
              https://simplybearings.co.uk/shop/Be...790/index.html
                There are smaller size belts available, but Stateside they're hard to find, Emco Maximats were made in Austria,
                both my Maximat lathes have metric hardware and belts with the exception of the leadscrews which are inch.
                  How exact is that size requirement? I find the 10X metric belt to be 10mm wide, 6mm height.
                  https://www.vbeltsupply.com/converma...atalog=product
                  Anything here close enough?
                  https://www.vbeltsupply.com/metric-w...rapped-belts//
                    Not ignoring this, I have put together a L3 (3/8) segmented belt to tide me over till I find the belts I (carefully) specified,
                    Yes other larger belts can (and do) work but the wider & deeper belts we have found will impede higher speeds
                    and the motor is 70 years old and only about a 1/3 horse so the belts it was designed to use will be best.
                    It is one of those frustrating searches, you know what you are looking for,
                    know that they exist and are "off the shelf parts" on the other side of the planet
                    but the search engines insist in flooding me with what they have instead of what I want
                    ... you must mean something else you did not say because that is what we can offer ...
                    One of the shops in south England (abco) that has *exactly* what I want
                    says they are looking up distributors in the US and will get back to me
                    e.g. https://www.abco.co.uk/Products/8mm-...n-v-belt/8-450
                    thanks all
                    I will also try contacting a couple of local bearing shops
                    The slightly larger but likely more flexible Polyurethane belt is available by the foot
                    (I once made tires for my band saw by fusing a strip like that)
                    And the "belt palace" site has a very close profile match;
                    Has correct 8mm width and only 20% thicker which is now my second choice
                    if I can get them in close enough lengths .
                    Tom C
                      Since you know that the exact belt you need is available in England and you have a temporary solution, have the shop in England mail you the belt. It may take a few weeks to get here but you have the time to wait since you have a belt that works.
