I understand that roller chains when properly aligned and tensioned running in enclosed oil bath housings reach efficiencies of about 95 % or more,
I have added a gearbox to our 4 inch scale Clayton steam wagon, that involved adding 2 chains, both #40 chain. These will be running in the open,one having 24 tooth sprockets as driver and driven and one having a 14 tooth sprocket driving a 40 tooth sprocket.
They are in pretty good alignment and will be run with the chains slightly slack.
Have there ever been tests done on chain drives run in these circumstances? Are they going to soak up much of my, none too great, power?
Regards to all David Powell.
