May need some help making piston rings for this…..
Piston ring help
Originally posted by sid pileski View Post
Nether. Alco engine, Auburn NY. Picked it up at the factory!Last edited by nickel-city-fab; 07-03-2021, 04:39 PM.25 miles north of Buffalo NY, USA
Are you going to mate this with a cylinder for a working engine? Or do you need the rings just for show? In that case, you can probably just get some steel (or even aluminum) pipe or tubing and bore/turn it to size, part off rings, cut a slot, clean up, and pop them on (using some sort of expander). Or maybe you can find rings for something else, that would be close enough.http://pauleschoen.com/pix/PM08_P76_P54.png
USA Maryland 21030
Originally posted by sid pileski View PostMay need some help making piston rings for this…..
The two on the left are used and are close in size to yours. I'm not sure what engine the one on the left was for. That one has never been used. I have a couple valves somewhere for it.
The small piston in the front came out of a 12 HP Briggs.
I have the rod to one of them.
JL..............
Originally posted by sid pileski View PostHey Joe, I was waiting for you to comment. I figured you’d be able to relate if anyone. That one in the right looks to be the same as mine. Funny, my brother has a rod like yours too.
JL..............
The threaded holes on top of these large pistons is there to accept an eye bolt used to pull the piston and con-rod assembly out through the top of the engine.Home, down in the valley behind the Red Angus
Bad Decisions Make Good Stories
Originally posted by nickel-city-fab View Post
Curious, I haven't heard of them. What is their primary application? EDIT never mind, it seems the Alco replaced the EMD but not the Cat. Locomotive engine and standby generator applications. Mfd by Fairbanks-Morse, whom I had thought were long gone.
I went to a tool auction at the Auburn plant and spent a lot time spelunking in the offices and dyno cells. Neat place.
- Likes 1
