A week ago or so I started a post about my old Campbell Hausfeld compressor pushing oil out of the crank case breather vent. This morning I pulled the head.
I found that the inside piston or fly wheel side was slightly wet. The cylinder walls look good, no scratches etc. didn't measure them but did try to wiggle the pistons and I don't detect any play.
Pretty tight still.
The reeds on the piston side of the head look good, (no missing screws) but when I tap lightly trap on each one with my finger I can hear that they are not firmly seated against the hole.
That may or may not be a problem as I don't remember how they were when I put them in. I doubt the reeds are bend but am more inclined to think either the mating surface is worn or there are some carbon deposits under them preventing them from completely sealing.
I checked my old head and those reeds are firmly seated, no ticking sound when I tap on them with my finger.
Here's the flip side. These two reeds are carboned up pretty good but are sealing. The three voids in the head were full of oil as you can see.
So I'm going to take the reeds out and clean everything up and see what happens.
You can see the carbon buildup through the four holes. that may be why the flip side reeds aren't sealing properly.
JL....................
Pretty tight still.
