Today I built the cylinder head for my engine. I still have to put the slots in the cylinder head and plate right below it to make cooling fins. The only aluminum part left to build now is the gas tank mount. So, I basically have a whole engine here in six parts. Tomorrow I hope to cut the cooling fins and make the gas tank mount, then it will be on to mechanical things.
T head engine by Brian
Originally posted by nickel-city-fab View Postme likee --- spent last night imagining ways to do it with one cam. I do want to get into the engine building scene
after sorting through this thread - this is going to be a great build - this engine is really shaping up and has a very good look to it, Brain you really can "crank them out" but quality on this one is already starting to shine through... keep it going she's a keeper...
👍 1
You're making excellent progress Brian. Don't sell yourself short, you do more in one day than many of us do in a week!
Odd isn't that as the older we get with less time to spend on this planet we adopt a hobby that is so time intensive.
When your main objective is to counteract boredom and engage in the pleasant process of machining, spending a whole day on one part seems like success to me.
This little piggy was just an antidote for "boar"dom, And you managed to "bear" it well!
👍 2
And---The miserable piggy of the day award goes out to this cylinder head. It is finished except for the cutting of the cooling fins, but I've managed to put in an entire day on this part. Some days you eat the bear----Some days the bear eats you!!! The bear eat me today on this part, but I'm pleased with it.
👍 1
Due to the way this engine is constructed, the swing of the con rod would hit the side of the cylinder bore on it's way to bottom dead center. This cavity in the bottom of the piston aligns with the cavity in the bottom plate which bolts to it, to give clearance for the swing of the connecting rod.
Brian really rips into a project when he gets started. He turns out good parts rapidly.
I do not work nearly that fast, although when I get motivated I do tend to keep at it until done.
Impressive progress Brian and I trust it will continue to go well!
John
Thank you rdfeil. This engine is a "summer surprise". I wasn't going to build another engine until fall, but these parts are rolling out of the mill and lathe and I'm liking it.---Brian
Great work Brian, as always!! That base and cylinder really look sharp!
We have a cylinder. It is pretty, it fits where it's supposed to, and after honing the bore with a 3 stone brake hone it measures about 1.001" bore. That's all for today folks. I will get some mounting holes drilled in the cylinder tomorrow.---Brian
👍 3
Well, so far, so good. The cylinder base mounts to the main chassis. Depending on what my wife has planned for me today, I might even get a cylinder up there.
👍 1
Someone needs to build a Charlie Taylor engine.
That would be neat.
-Doozer
