Going from .026 to .049 is a big jump in spring pressure. I bet the new springs will seal the valves, but may put a lot of wear on the cams. Time will tell.
T head engine by Brian
Originally posted by brian Rupnow View PostToolguy--that is why I made the cams and lifters from 01 steel and hardened them. You could pound on them all day and not hurt them.Southwest Utah
- Likes 1
The Helicoils worked great. I have never used them before and I must say, they work fine and don't require a lot of work to use them. I did machine new spring cups and install them and the heavy valve springs on the engine, but it didn't really help. I then took the cylinder head off the machine and ran a 0.200" diameter drill up from the bottom side of the valve cages, about 0.6" to cut down on the amount of friction between the valve stems and the valve guide portion of the valve cage. I took the heavy springs and cups off and put the originals back on. I reground the valves. Nothing really helped get my compression back. Something I have noticed over the years--When the seat portion of the valve cage gets too large, it is almost impossible to get a good valve seal. I'm stumped at the moment. I may machine new valve cages and reface the valves in the lathe, more or less starting over again with the valve sealing issue. I have rechecked the valve and ignition timing, but they are fine.Brian Rupnow
Design engineer
Barrie, Ontario, Canada
Originally posted by brian Rupnow View PostThe Helicoils worked great. I have never used them before and I must say, they work fine and don't require a lot of work to use them. I did machine new spring cups and install them and the heavy valve springs on the engine, but it didn't really help. I then took the cylinder head off the machine and ran a 0.200" diameter drill up from the bottom side of the valve cages, about 0.6" to cut down on the amount of friction between the valve stems and the valve guide portion of the valve cage. I took the heavy springs and cups off and put the originals back on. I reground the valves. Nothing really helped get my compression back. Something I have noticed over the years--When the seat portion of the valve cage gets too large, it is almost impossible to get a good valve seal. I'm stumped at the moment. I may machine new valve cages and reface the valves in the lathe, more or less starting over again with the valve sealing issue. I have rechecked the valve and ignition timing, but they are fine.
Chipmaker--The valve cage is a one piece unit that has the valve guide and the valve seat all carved from the same piece of material, brass. It is finished everywhere except the valve seat. Then it is lightly pressed/mostly Loctited into the cylinder head. Then a special guided tool is inserted into the valve guide portion and turned by hand to cut the valve seat. The valve is machined to size, then inserted into the valve cage after the Loctite has dried. Then some 600 grit grinding paste is applied to the seating area of the valve and the valve is rotated by hand against the valve seat to make an airtight seal.---and about 75% of the time it does just that. 25% of the time, you won't get a good seal, and it will drive you crazy trying to figure out why.Brian Rupnow
Design engineer
Originally posted by brian Rupnow View PostSparky---Today I tried everything I knew about, and half a dozen things that I didn't.---I'm going out to the garden now and eat worms!!!
I suggest using the worms for fish bait and eating the fish. It is relaxing and allows you to think easily AND provides a tasty dinner!!! You will figure it out as you always do 🐟Robin
Happily working on my second millionGave up on the first
- Likes 1
Originally posted by brian Rupnow View PostChipmaker--The valve cage is a one piece unit that has the valve guide and the valve seat all carved from the same piece of material. . .Last edited by chipmaker4130; 09-15-2021, 07:18 PM.Southwest Utah
