Three angle valve grinds are used on most production M/C, automotive, industrial, etc.engines that I have service manuals for, some dating back to the '30s.
In reality it is the only way to narrow the contact patch for good sealing and to center it.
However I can certainly sympathize with Brian's plight in doing so on an almost microscopic level.
All I can suggest is to keep the lapped contact area small in order to increase unit pressure in that critical area.
T head engine by Brian
Originally posted by brian Rupnow View PostRingo--We're talking about a valve that is 3/8" diameter at the head. I think a 3 angle grind is two angles beyond what I can do.
Originally posted by brian Rupnow View PostChipmaker--The valve cage is a one piece unit that has the valve guide and the valve seat all carved from the same piece of material. . .Last edited by chipmaker4130; 09-15-2021, 07:18 PM.
Originally posted by brian Rupnow View PostSparky---Today I tried everything I knew about, and half a dozen things that I didn't.---I'm going out to the garden now and eat worms!!!
I suggest using the worms for fish bait and eating the fish. It is relaxing and allows you to think easily AND provides a tasty dinner!!! You will figure it out as you always do 🐟
- 1 like
earlier you mentioned that if the valve seat area is too wide it becomes difficult to seal.
Have you tried a 3-angle valve job?
Chipmaker--The valve cage is a one piece unit that has the valve guide and the valve seat all carved from the same piece of material, brass. It is finished everywhere except the valve seat. Then it is lightly pressed/mostly Loctited into the cylinder head. Then a special guided tool is inserted into the valve guide portion and turned by hand to cut the valve seat. The valve is machined to size, then inserted into the valve cage after the Loctite has dried. Then some 600 grit grinding paste is applied to the seating area of the valve and the valve is rotated by hand against the valve seat to make an airtight seal.---and about 75% of the time it does just that. 25% of the time, you won't get a good seal, and it will drive you crazy trying to figure out why.
Originally posted by brian Rupnow View PostThe Helicoils worked great. I have never used them before and I must say, they work fine and don't require a lot of work to use them. I did machine new spring cups and install them and the heavy valve springs on the engine, but it didn't really help. I then took the cylinder head off the machine and ran a 0.200" diameter drill up from the bottom side of the valve cages, about 0.6" to cut down on the amount of friction between the valve stems and the valve guide portion of the valve cage. I took the heavy springs and cups off and put the originals back on. I reground the valves. Nothing really helped get my compression back. Something I have noticed over the years--When the seat portion of the valve cage gets too large, it is almost impossible to get a good valve seal. I'm stumped at the moment. I may machine new valve cages and reface the valves in the lathe, more or less starting over again with the valve sealing issue. I have rechecked the valve and ignition timing, but they are fine.
Brian, how do you maintain alignment (square and concentric) of the valve seat with the valve guide? In a commercial setting valve seats are ground after insertion or repair of the valve guide and it is done using a mandrel in the valve guide for alignment/concentricity.
I didn't realize they were hardened tool steel. They'll be fine. I will have to read more carefully next time.
Yes, they will wear. They won't "wear out"--Not in my lifetime anyways. It is a model, not a 24 hour a day powerplant.
Originally posted by brian Rupnow View PostToolguy--that is why I made the cams and lifters from 01 steel and hardened them. You could pound on them all day and not hurt them.
- 1 like
