Having a lazy day today. When I was reducing the 1144 roundstock for my crankshaft from round to flat the other day, I noticed that the cut was different in one direction than the other in the X axis. This is a sure indicator of a mill being out of tram. I tore down my set-up and got out the steel brake disc that I use for tramming the mill. Using my coaxial indicator I trammed the mill, then replaced the mill vice and part being worked on. Then I used a 2" face mill to mow away the other side of the round stock, and ended up with a flat bar of 1144 stress proof steel to make a crankshaft from. Not a lot of actual progress, but now I have the material to go ahead and start machining a crankshaft tomorrow.
