Cordless Drill Meltdown
  • Cordless Drill Meltdown
    I was drilling some 1/4" drain holes in some 11gauge tubing this morning and started noticing a hot plastic smell. Couple holes later the drill changed it's tone and things went sideways. I can't complain, it's only drilled a million holes and ran in god knows how many Tek screws. I just got a chuckle out of a gearbox meltdown instead of the more common electrical meltdown
    You may only view thumbnails in this gallery. This gallery has 1 photos.
    Looks like the lube finally ran out. Maybe literally?
      I was working with a home builder a few years back. He asked me if all that heat generated in a hot drill bit pulled out of a piece of wood came from the batteries of the cordless drill? I replied "yes. all that and more! no machine is 100% efficient.
      Heck, Teslas burn to the ground every couple of weeks if the news has it right.
        It would be interesting to see the insides of that drill. I have a B&D corded drill that started running poorly, especially in reverse, and I found a sleeve bearing on the rotor shaft had worn to an oval pattern which misaligned the brushes and commutator. I had a ball bearing of the correct size, popped it in, and Bob's yer uncle!
ID:	1950536 Click image for larger version
        The gear train is surprisingly robust for an inexpensive 3/8" B&D hand drill:
        USA Maryland 21030
          Crazy the drill puked out its guts. You definitely got the use out of that one. JR
            Here's the guts of one of my Ryobi cordless drills that fell off a roof too many times. Drive train and motor are still good, but case needs some TLC (and maybe JB Weld)?
            USA Maryland 21030
              Did something similar with an impact driver at work. Coworker spilled a gallon of latex paint on it, washed it out and we kept using it until it died. When it finally did, it was pretty dramatic, giant clouds of smoke shooting out the casing and all
                The gearbox itself is fine, it's the typical little two speed epicyclic type. It looks like the little prong that shifts the box between speeds broke and that let the gearbox housing (acetal) spin inside the clutch housing (nylox) . That's melted plastic running out the bottom in the pic
                  That gearbox is nearly identical to the one in the Hitachi. One of the guys at work had a similar drop test fail on a Makita 1/2 impact wrench. He filled the handle full of JB Weld plumbing repair, which is non-conductive and then wrapped it in a layer of friction tape. Works fine and it's a good save, those things are nearly $300 new.
                    Yep, I cannot complain, it died gallantly. This one was a brush motor, the new one is brushless and supposed to have a bit more umpf behind it, should be interesting.
                      As long as you can still fit the old batteries to the new drill, you can hope the new one lasts as long as the old one. A mate of mine bought a new Hitachi and couldn't get along with the chuck, we swopped it for the chuck on his broken DeWalt and he is happy now.
                        Funny failure mode. I let the smoke out of my little beloved 12v hitachi 1/4" hex driver a while ago. Brushes caught fire while deburring some holes. Still haven't got around to tearing into it to see if I can fix it. Had the same happen to my makita drill some years ago, and replaced the brushes and all was good.
                          Does that one have a Rohm Chuck?
                            No, it came with the typical plastic and aluminum chinese chuck. Awhile back I replaced the factory chuck with an LFA carbide jaw one. Much, much better chuck, the carbide jaws are worth it , made in France.
                            http://www.lfachucks.com/portable-to...ss-chucks.html
                              I had this for a few weeks then noticed the Rohm Chuck,seems to be good. Click image for larger version
