I have been in the process off and on of rebuilding my older Quincy compressor. I am now considering making my own pistons. My question has to do with material choice. The original pistons are made out of cast steel. Could anyone recommend a steel to use, such as 12l14 or 1144 stressproof. Thanks
New Pistons for compressor
Hrm,,, the 12L14 will certainly take a better finish (and maybe easier to hold tolerances on) but the 1144 is well, stress proof as it says. That's a tough call, but I think you would be OK with either one. Depends how hard you use the compressor. I know the 12L14 is good for 50ksi, and the stress proof is double that, but do you really need it in a compressor? Consider that a lot of compressors use aluminum pistons and get away with it.25 miles north of Buffalo NY, USA
I was thinking of the 12L14 or stressproff for the wear not just the strength. I am using steel instead of aluminum to try and keep the weight as close as I can. It only turns may be a 1000 rpm probably less but there is a balance factor to consider. I was just wondering if there might be a better material for the wear characteristics.
Originally posted by quadrod View PostI was thinking of the 12L14 or stressproff for the wear not just the strength. I am using steel instead of aluminum to try and keep the weight as close as I can. It only turns may be a 1000 rpm probably less but there is a balance factor to consider. I was just wondering if there might be a better material for the wear characteristics.25 miles north of Buffalo NY, USA
Originally posted by nickel-city-fab View Post
Pretty sure that any kind of steel is going to have the same wear characteristics unless you use hardened and ground tool steel, like D2 or A2. So basically it's a toss-up for the steels you listed.
The OD, length and distance from pin center to top are all critical dimensions. Cut your ring grooves to size and position and then start hollowing out the inside until the weight is matched to the original. Sound like a chore to me.
JL................
Pistons are commonly turned oval below the rings, I dont know if the cooler working conditions with compressors requires that. The bores would certainly have to be refurbished before making the new pistons or it would be a waste of time. New rings with a ridge dodger top ring would be the easiest way to give the compressor a new lease of life.
Yes it will be a learning experience on how to machine the interior of the piston. The pistons are flat top, no cir-clip groves and round not oval like a hi-performance automotive piston. New over size pistons are available but very expensive. Last night I priced 12L14 and 1144 from online metals and speedymetals and was shocked at the price.
Originally posted by quadrod View PostLast night I priced 12L14 and 1144 from online metals and speedymetals and was shocked at the price.25 miles north of Buffalo NY, USA
Originally posted by quadrod View PostYes it will be a learning experience on how to machine the interior of the piston. The pistons are flat top, no cir-clip groves and round not oval like a hi-performance automotive piston. New over size pistons are available but very expensive. Last night I priced 12L14 and 1144 from online metals and speedymetals and was shocked at the price.
Sometimes you better off buying the painting rather than trying to copy it !!
JL.............
I have been and will continue to watch ebay, so far nothing large enough, I need one piece 2 5/8 x 6" and one piece 3 5/8 x 6''. The bores of the compressor are 2 1/2 and 3 1/2". At some point it may be cheaper just to buy an inexpressive compressor to stick on my tank.
