I have a dehumidifier that has a small unit motor/pump.
The pump is not working. When I investigated, I found that the 1/4" faston connections to the pump are corroded, and the wires leading to them have melted insulation. It has an over-temperature cutoff, which is outside the case, adjacent to the connections.
The pump case does not look in any way overheated.
But obviously there is a problem.
The question is whether the issue is due to the corrosion making bad connections, or due to the pump itself overheating. I suspect the cutoff would have shut it down well before melting wires if it were the motor..
Other info:
The motor needed a new capacitor a couple years ago, the old one opened up. After replacement, it worked fine. That replacement cap is fine still.
I can fix the wire problem, but prefer not to take the trouble if the motor is likely to be bad.
So:
Is it fairly common to have corroded connections in an otherwise working unit? Being a dehumidifier, there is always water around it, so it seems reasonable.
Does the melted insulation suggest anything past the lousy connections?
Can these motors be effectively measured in any way that indicates damage? I can measure resistance, insulation to case, etc. I found no issues so far with what I would consider reasonable tests..
It's a pain to reassemble to working condition just for a test, and there is a broken standoff for the relay PWB, for which the glue is drying now, and I'd rather not assemble the unit for a test of function until later.
I'd also rather cut my losses if there is an obvious symptom of failure.. I can replace it, but I prefer to fix if that is reasonable (a new pump is NOT reasonable). But I know little about refrigeration type unit pumps and their common failure symptoms.
Other info:
So:
