This is a followup to the Tree ram repair post in Jan 2021. I tried to attach the link to that post but couldn't get it to work.
The initial plan for the head was to retrieve the spring clip I dropped in the spindle housing, install new belts and change oil in the gear box. But that wasn't in the master plan as you will see. The **** hit the fan (so to speak) when I pulled the cover off the gear box and discover the spindle nut was damaged and loose and machining a nice groove in the gear box cover. Also the driven cogged sheave appeared to be setting proud of the mating surface for the gear box cover and was therefore doing some machining of it's own in the cover.
spindle nut
under side of gear box cover
So I decided to bite the bullet and do a complete rebuild and repair. After all I already had a couple grand in repairing the ram Tee slot and worm wheel.
Photos of the head before cleaning and repairing.
looking into the gear box
parts and pieces
More to follow.
spindle nut
parts and pieces
More to follow.
