Lift Table Booster Block
  • Lift Table Booster Block
    I recently purchased a small Durhand scissors type lift table (16 1/2" x 13 3/4"). It has a 300 lb capacity, and raises objects from just under 14" to to a height of 36". It has 4 swivel casters (2 locking), and requires maybe 20 pedal strokes from bottom to top. It cost around $180 with free shipping at:
    www.aosom.com.
    When fully extended, it will only reach the surface of my Bridgeport table when the knee is almost all the way down. I wanted to avoid having to raise and lower the knee to remove or replace my vise and rotary table, particularly with a substantial weight on it. The answer was to make a booster block out of 2x8s and plywood as shown in the photos. A small rectangular piece screwed to the bottom of the block registers in a matching hole in the table top to keep it from sliding around.
    The table will easily lift any item I am likely to use on my mill, and takes up very little floor space.
ID:	1951420 Click image for larger version
ID:	1951421 Click image for larger version
ID:	1951422 Click image for larger version
ID:	1951423 Click image for larger version
    Nice find. The smaller footprint makes more sense for most of our garage workshops.
    Here's a direct link:
    Glenn
    So many projects . . . so little ambition! Arroyo Grande, CA
      www.aosom.com.
      Great idea!
      It looks like a natural application for "FOAM" core to keep the weight down. (Blue board or pink, your choice!)
        I got one of the import 600 lb hydraulic lift carts 15 years ago or so and the older I get the more useful it becomes. Best $250 I ever spent.
