While magnetic drills have many great uses, they are held back by their limited throat depth. I overcame this problem for my mag drills by fabricating drill press stands for them. I used 50 lb. bases from Walker Turner 15" drill presses, tilting tables from Delta DP200s , and 2 3/4" OD - 1/4" wall DOM (drawn over mandrel) steel columns 48" long. Other than the columns, all parts were purchased on eBay.
One mag drill has power down/up feed, and the other has variable speed with reversing. Both have two speed gearboxes and a 2" annular cutter capacity. I put these together before I bought my Bridgeport mill, but still use them extensively. They can be quickly lifted off the stands for use elsewhere.
