Storage for Reddi Rod and small rods.
  • Storage for Reddi Rod and small rods.
    Just picked up more stuff from storage from my old shop.
    .now if I dont put it in avisible location i wont find it when I need it.
    so i made a few of these.. Click image for larger version
ID:	1952072 how are you guys storing yours?
    When I saw rod I automatically though welding rods. I have stuff stored on racks above my overhead doors, under one of my old welding benches and in every corner of the shop.
    I do have everything inventoried so I know exactly what I have, how much of it, where and when I bought it and what I paid for it. I do however have my TIG rods well organized.
    JL.............
      Here is the mess I have, the rods are in the PVC pipe. Click image for larger version
        Originally posted by true temper View Post
        Here is the mess I have, the rods are in the PVC pipe. Click image for larger version  Name:	CCA1C62B-409B-4194-96F0-71DFD18F3848.jpeg Views:	4 Size:	802.6 KB ID:	1952112
        I made a few PVC cans for my 36" fillers for the TIG. I dont do any stick welding anymore {
        For my cans I just bought some tube, glue and threaded fittings, inside thread for the caps. . Like everyone does. Thats how I learned it..
        The tubes ar cheap and work as well as anything on the market. HSM....JR
          P.S> I love that shop.
            I used black painted 6061 tubing. I wanted horizontal , to much crap on the floor. And now I can put a 7 inch piece in it and still see the end of it.
              That welding rod storage rack looks very nice. It is always so much easier to store things that all share at least one dimension.
              Now, I guess you are going to tell us that the handle in the middle makes it easy to carry the rack to the job. I want to see a picture of you doing that.
              Seriously, I have an ongoing battle to organize my shop and I love to see these threads about the different ways others do it. Keep them coming.
              JL.............
                Looks like it's on casters.
                JoeLee how do you store the remnants of your TIG rods?
                  A rack under my bench grinders for the long stock.
                  Click image for larger version  Name:	P1020183.JPG Views:	0 Size:	98.9 KB ID:	1952187
                  This graduated length assembly of 4" PVC tube for pieces from 5ft to 17". It puts the metal standing on end so I can instantly see the cross section on the end and the length by how far up it stands. Plus I don't have to move anything to lift out what I want or to replace the excess into the right new spot based on length. It has been an excellent use of floor space for storage of the offcuts.
                  Click image for larger version  Name:	P1030906.JPG Views:	0 Size:	102.1 KB ID:	1952189
                  Then once down to 16.5" and shorter it all goes into the old file card drawers in this side of my center island for the shorter lengths. Different drawers labeled for round stock, flat stock, tool steel, aluminium, etc.
                  Click image for larger version  Name:	P1020377.JPG Views:	0 Size:	118.6 KB ID:	1952188
                  Chilliwack BC, Canada
                    I use square plastic fence post so I can lay them on a shelf and stack them. I use short ones on top for cutoffs and misc short pieces. It’s a nice way to separate rounds, square and flats by material type.
                      I don't really know why I put that handle there. Sure as hell can't lift it. I had to top it off with something decorative. Think of it as a finial. It rotates and locks in position both ways too.
                      This is how I made the cross sections. It was pretty time consuming. I milled a square block to use as a spacer for each square and put a dab of weld on the bottom side of each joint.
                      The ends were drilled and pinned. then I fused around the seam.
                      I made the tubes out of central vac pipe / tube because that stuff is thin wall sched. 20 and measures 2" on the OD unlike sched. 40 PVC pipe. I plugged the bottoms with PVC round discs that I cut to about 1/2" in thickness. The flat top end caps were made for that type pipe.
                      JL..............
                        That Sir is one of the best questions I have heard from you.
                        I TIG weld and am pretty conservative when it comes to filler. I conserve all mine..
                        Always looking for a better way.. Thanks Reggie.. JR
                        I drop my ends off into a stainless coffee pot bucket and fuse them back together and make 22" long frankensteign filler rods. haha
                        They look like hell, bunch of 1-2 inch sections all fused up /
                        Yeah, it works FYI JR
                        Yup
                          My smaller stuff goes on a Mobile Cart equipped with a Mini Bandsaw and other stuff on larger rack. Click image for larger version
ID:	1952299 Click image for larger version
                            No, it's not on casters.
                            Here is where I store my remnants. I almost always cut the 36" rods in half. I had planned on making some short tubes and a small rack to sit on the side of the machine for the remnants, but haven't got around to it yet. I have several 21" long pieces of tube that were left over from the full lengths. Some day !!
                            JL...............
                              Some great ideas on here.. shorts can be a pain.. that is why I chose Horizontal storage, and it uses space that is not being used.
