If I can't just try the mating part on the part I am making I use thread wires. A set of them is not overly expensive and they really are not very difficult to use. As a hobby shop, generally my requirements are only that the thread fits reasonably well, I rarely need to make parts to some defined spec or standard. And in my experience anyhow, if a thread I cut measures OK with wires, it will fit and fit nicely. That's usually as close as anything I make needs to be.
How do you check your threads when threading on lathe ?
Something else to consider....... the topic of this discussion is threading on the lathe. To me that implies single point threading, but it might also cover threading from the tailstock using a die.
Threading with a die held in the tailstock quill and pushing the tailstock along can be a big problem. The common problem is the pitch of the thread is not guaranteed to be consistent since it relies on an even pulling/pushing of a relatively heavy tailstock. Without an even feed of the tailstock you get shaving of the thread flanks causing uneven pitch.
I picked up a good customer when I made some adjusting nuts to fit their screws. They returned my nuts saying they didn't fit their screws. My nuts were correct according my thread gages. It turned out their screws were made with a button die tailstock method. Checking their screws in the optical comparator it was obvious the pitch varied over a one inch segment. I got the long term job of making both the screws and nuts.
An optical comparator can check all aspects of an external (male) thread.
Originally posted by DR View PostSomething else to consider....... the topic of this discussion is threading on the lathe. To me that implies single point threading, but it might also cover threading from the tailstock using a die.
Often when threading with a die in the tailstock, I leave the tailstock loose
and just shove on the end of it until the die and threads start feeding themselves.25 miles north of Buffalo NY, USA
Originally posted by 754 View PostFew things are as satisfying as cutting a Nice thread by single point... with insert tooling.. it gets very easy ..
may as well learn it, you wont always have a die handy..
And for finer pitches, I often times use a triangular carbide insert.
If it is a coarse pitch and I need side rake, I have no issues grinding a HSS toolbit.
Now I have graduated to a better lathe than most have access to.
My Hardinge, my Hendey, and my Pratt & Whitney lathes all have single dog threading.
But I often thread on the big LeBlond lathe at work, still fun as can be.
-DDZER
- Likes 1
I hope your picture does NOT give anyone the impression
that these are thread gauges, which of course they are NOT.
-Doozer
They are what they are, thread checkers. JR
Edit: Here is my answer to the original post
"I'm not good on threading on the lathe. The way I check my cut threads is to test it on the either male or female part I am making the thread for..
When cutting threads on the lathe I am almost certainty cutting it for an already cut thread. So I try to match it as best as possible for my skill."Last edited by JRouche; 07-21-2021, 02:45 PM.
Thats exactly what I would do if the mating part was available, then the two can fit as tightly or loosely as I want. I once made a 1/2" ACME two start male thread for a copy of the lathe toolpost. When I got to the size according to the charts, it was not even close to screwing into the top slide. Luckily the female thread was available and I kept taking a bit off each start until it fitted. I have no idea why the lathe manufacturer made the thread 10% undersize.
Originally posted by old mart View PostThats exactly what I would do if the mating part was available, then the two can fit as tightly or loosely as I want. I once made a 1/2" ACME two start male thread for a copy of the lathe toolpost. When I got to the size according to the charts, it was not even close to screwing into the top slide. Luckily the female thread was available and I kept taking a bit off each start until it fitted. I have no idea why the lathe manufacturer made the thread 10% undersize.
I agree. Very fun to cut threads in the lathe.
-D
I prefer lathe-turned threads, they are just a lot better.
But where it doesn't matter, or if I can't justify the time spend
I'll just buy a box of bolts or whatever.
I very rarely use my dies any more, mostly for repairs nowadays.
But I love the adjustability, I have the antique 2-piece Greenfield/Wells Bros dies.
Like this set: https://www.ebay.com/itm/32472185672...UAAOSwvRBg901X
You can get any kind of fit you want with them.Last edited by nickel-city-fab; 07-21-2021, 06:45 PM.25 miles north of Buffalo NY, USA
I never understood this but I have seen it too many times before.
If you have a nut, why not just cut with the lathe until the nut fits ? ? ?
-D
