Any info on these Clamps.?
I see the two images.
I thought Carver Clamp, but not quite the same: https://www.freertool.com/carver-clamps-2
Check the hole the tensioner goes through to see if it has full threads or if it has threads on one side at the top and the other side at the bottom. Fast action screw, tilt the block and slip it until it is nearly tight, then let it tilt the other way so the threads engage and tighten it.
The screw is aporox 7/8 dia. With a smooth part about 1/4 inch dia or less sticking out about 7/16 or so.
that pit in the pivot block, and the end if the screw turns against the block.. will try to get a pic.
when slackened off the pin portion , comes out of the block (nothing holds it) then the jaw and the oart with screw start moving all over.... not connected to each other.Last edited by 754; 07-18-2021, 05:02 PM.
