I don't know what else to call these. Made five of these yesterday, various sizes, because I had to come up with a way to accurately cut these holes equally through the center.
My scribe lines aren't accurate enough and are there just for visual comfort. After the first hole is located it's all DRO's from there on.
This is what I have been ending up with. Discrepancies of up to .020 or so. It's really hard to eyeball the blade in the center of the hole. I tried measuring and a couple other ideas all of which were nerve racking and I kept ending up with the same error.
You can see that the inside of the holes are all perfectly aligned and that's all that really matters, DRO's work great.
So, I came up with this idea............ I turned the plugs to about .001 under the various hole sizes and then slit them on center in the mill.
My band saw blade cuts .045 wide and I had a slitting saw that cuts about .0455. The slit fits the blade with no wiggle. If I can minimize my error down to about even .010 I would be happy.
With these plugs I should be able to do that and the set up will be much less nerve racking and quicker.
JL...............
JL...............
