Correct procedure for posting viewable photos?
  • Correct procedure for posting viewable photos?
    When I post a picture it comes out as a small blurry snapshot but I have seen other people put up images that are a nice viewable size and can be expanded without losing quality. What am I doing wrong?
    Click on "Upload Attachments", which opens a "File Upload" window. Use the usual Windows Explorer navigation to the images you want from your computer, and click on them. You can select as many as five images by using Ctrl-Click. Click the "Open" button and the files will be uploaded to the HSM server. They will appear below the edit frame, and you can select from:
    thumbnail
    small
    medium
    large
    and Fullsize:
    I like to have my images pre-sized 20% to 800x600 pixels from the native 4000x3000, but 1200x900 (30%) is also good. So my "full size" image is the same as "large". But otherwise it will be resized to fit the page, like this which is the original 4000x3000.
    USA Maryland 21030
      thumbnail
      small
      medium
      large
      and Fullsize:
      Thank you for the information Sir.
        When I post pictures, I normally choose thumbnails which may be a mistake, because only people who are signed in can see them fullsize. I must remember to choose fullsize as most of the people viewing are not members.
          Why does your dog look guilty?
            Thanks for the information PStechPaul, I will try that next time.
              If it helps any... I always resize my pics to 1600x1200 on the desktop, and when i upload them I wait for the uploader to get done, then select "medium" size. Et Voila, the pic appears, medium sized.
                An alternative to the so many pixels by so many pixels is to check the image for size. Something around 180K for file size will be OK but a touch fuzzy. Images that are up around 250 to 280K will be sharp and expandable. It's not a great idea to go bigger than that since it's not really needed and it can be a slow down for those with slower connections.
                Chilliwack BC, Canada
                  Paul Thanks for the help..This sounds like a ten step process. Does this forum use some hyper complicated secure software to thwart international hackers? I can sit in my garage with my iphone and take some pictures of some hubcaps and post them on craigslist all in .about 2 minutes.. Edwin Dirnbeck
                    Three steps:
                    1. Click "Upload Attachments"
                    2. Select desired photo - it will appear below
                    3. Click on desired size ... DONE!
                    USA Maryland 21030
                      Issue with posting anything but thumbnails is that someone quotes you and leaves your image links in the quoted post, instead of just quoting the text.
                        That's a "them" problem though. Let's not penalize the rest of us that enjoy the big pictures and know enough to only quote text or even just a line or two of the post.
                          Hardly.
                          What's wrong with clicking on a thumbnail? You can enjoy the big pictures if you choose and skip the less interesting or less photogenic shots.
                          No one size fits all.
                            I was wrong about the photo size in my post #4, I have just viewed PStechPaul's #2 post without logging on and every picture is thumbnail size, and they stay that way even if clicked on. Not much encouragment for potential members.
                              I like being able to read the text of a post while at the same time viewing the relevant picture. And as such I like to have a short description of the following image just above it.
                              More tips:
                              If you find an image that is already on a website, you can usually Right-Click and choose "Copy Image Link". Then in your post editing, you can click "Upload from URL". Otherwise you can choose "Save Image As" and download it to your computer. This is useful if you want to edit the image before posting, by resizing, cropping, adding text, etc.
                              Sometimes images on websites do not directly allow this, or the image may be in a format invalid for the post. In that case, you can usually Right-Click and select "Take Screenshot", which allows you to select the entire page or a portion. This can be downloaded to your computer and then edited and used for forum posts as you wish.
                              George - it would be helpful to make some of this info available in a sticky. It could even include a short video of the process. Here is a video clip of another way to insert images using drag and drop, although apparently it does not always work for everyone:
                              Like this:
                              Oktoberfest Potato Salad
                              USA Maryland 21030
