Another Must Have Tool !!
  • Another Must Have Tool !!
    I always wondered why I had difficulties removing V belts. I just didn't have the right tool !!
    https://www.homemadetools.net/forum/...111#post185111
    JL..............
    Looks like a web site contrived to steal intellectual property.
    -D
    DZER
      Can't read the text on his dimensioned photo!
        I have long been suspicious about that site. Subscription ($) is required to post, but they will "volunteer" your content from a personal site or message board free of charge.
        EDIT: Watched the video and it does look like a neat little trick. I might design one in OpenSCAD and see if it prints strong enough with 75% infill.
          Seriously ..you have to draw that to make it ? You are kidding ..right ?
            You have to draw it to 3D print it.
              Why would you print it .. you can build it in 20 minutes with a file and sandpaper...
                I would think that one could make several in 20 minutes.
                Sarge41
                  I can take a belt off in 2 seconds with out it, unless it has keepers or a guard around it. Duh !!!
                  Besides, prying a belt off isn't the best thing for the belt ! especially if it has a lot of tension on it. I've seen people do the same thing with a screwdriver.
                  JL.............
                    -That's exactly what it is. The guy swipes posts from a bunch of places, almost never asking to do so, and reposts them on his site. I'm given to understand he's even printed books.
                    He's had several of my projects, originally posted here and on PM, as well as ones lifted straight off my website, for years.
                    Guys like him are one of the reasons every photo I post publicly has my website URL on it.
                    Doc.
                      The internet is rife with IP theft. I've had full articles lifted off my website word for word including typos.
                        There are plagiarism checkers available that can scan for similar text over millions of published articles.
                        https://www.grammarly.com/plagiarism-checker
                        https://writing.chegg.com/
                        http://ii.library.jhu.edu/tag/plagiarism/
                        http://ii.library.jhu.edu/tag/plagiarism-detection/
                        https://www.scientificamerican.com/a...ycat-articles/
                        USA Maryland 21030
                          Used to be able to use Google, but since they muddied their results not so much.
                            Doc.
                            Not much different than what a certain lawyer did on his site.
                              JL.............
                              This! The only way that "tool" would be safe to use is if the belt was spring loaded. If a belt is properly tensioned without being spring loaded, using that tool will damage the belt.
