I found some crap furnature bolts once that I put some stainless locknuts I had. It was for a rake, so I didn't really care. When the first two siezed up, I just assumed by thread pitch was slightly wrong and cranked her home. Crappy field repair ya know. Well on the last two I put a drop oil on, and they sailed right down. I have been wary ever since.
Loving stainless steel nuts and bolts
Originally posted by A.K. Boomer View PostAgree with most everything you wrote Dooze except for the "get it gun" if I have a direct line to engage the gun then it's actually my go too tool for stubborn nuts and bolts, but i use kids gloves --- I set the air input way down -- I then hit the fastener with penetrating oil --- I then let the gun do it's thing --- vibrate and work the penetrating oil into area and then hear that ZING sound when things finally break loose....
I do believe that works. Probably a very good idea. I just have a hard time to determine if the bolt is actually
moving or if it is seizing. With a hand wrench I can always (most always) tell. Maybe I am being too careful
and need to expand my horizons.
-DoozerDZER
Originally posted by Edwin Dirnbeck View PostI am an old guy and keep my stuff forever.I have a very large selection of stainless nuts and bolts. For the last 20 years or so ,I have been routinely replacing plain steel hardware with stainless ,when I am repairing things.I know that there is an old wives tale about stainless nuts and bolts seizing up. Dont believe it.Now I am not talking about high strength suspension parts.I work on a lot of outdoor stuf ,like mowers ,four wheelers ect, If you cant afford stainless bolts ,try using stainless nuts with plain steel bolts. You can buy ss nuts online almost as cheap as plain steel The next time you take it apart ,you will be smiling..Edwin Dirnbeck
Yes, I have heard many people like to use the impact wrench to help shock loose rusty or seized fasteners.
-Doozer
All of the above. I helped work on (as in repair) a commercial fishing boat starting when I was a teen. Never-seize and stainless bolts were an absolute must. As others have noted, I, too, have had a nut seize on a bolt just by hand-turning it. That's the nature of the beast- it "cold welds" if you so much as look at it funny.
But pretty much anything as a coating or lubricant will prevent that. We used never-seize, of course, because that's what it's fir, but barring that, a drop of motor oil, gun oil, a wipe of beeswax, spray WD-40 (although you risk it drying and galling later upon removal) Loctite, pipe sealant, whatever. Anything that prevents dry metal-on-metal contact.
Following that advice, I've been using stainless on anything that might get exposed to weather. Cars, trucks, outdoor fixtures, trailers, you name it. As noted, it's often been a godsend going back to the assembly years later.
But, also as others have noted, hardware-store grade stainless is a pretty low grade. The rule of thumb I was told, years ago, was consider it basically Grade 3. Better can be had, but if you're just picking it up from ACE or Home Depot or something like that, it's pretty soft. Worth keeping in mind if you're dealing with something that may have a lot of stress on it.
Doc.Doc's Machine. (Probably not what you expect.)
If I have to remove any SS hardware, or any hardware and I'm not sure if any anti seize compound was used I use this stuff................. https://blasterproducts.com/product/...ter-penetrant/
JL.............
Originally posted by ikdor View PostI've seized SS hardware just by running a nut on by hand. They were new though which makes it more likely.4357 2773 5150 9120 9135 8645 1007 1190 2133 9120 5942
"There's no pleasing these serpents"......Lewis Carroll
Edward, I'm totally with you on this one. I have been assembling drawers to fit into 19" racks, nad I'm using stainless steel fastenings, all Ebay/China. I've amassed a nice collection in the M2, M3 & M4 sizes, various heads. I love them! Strong enough for what I need, great finish, they look nice and they're dirt cheap.
Remember: shiny is good.
IanAll of the gear, no idea...
Originally posted by psomero View PostInferior mechanical properties, that SS crap. Good luck on high proof joints when the heads pop off.4357 2773 5150 9120 9135 8645 1007 1190 2133 9120 5942
- 2 likes
You know, any joint in a high confidence structure needs to be "designed". When a fastener fails, you used the wrong one or the wrong quantity, or used it wrongly. An SS bolt is as good as any other fastener when used properly.
I've used some very high quality fasteners on some custom suspension applications where appearance did take a back seat to performance.
ARP makes some very nice stuff rated @180,000 psi tensile strength, not cheap though.
Originally posted by deltap View PostMost hardware store stainless (8-18) is weaker than grade 5 steel fasteners. If replacing grade 5, new fasteners should be at least the same strength.
