Aluminum
  • #16
    Fastrack, I just checked with my son who was in the Supermileage program in high school and the Formula SAE in college.
    The supermilage car that they built in high school had an all aluminum frame and only weighed about 75lbs. I do recall going to the high school competitions and seeing some of their aluminum welds break. They had to repair them on-site with that perforated strap that plumbers use to hold up pipe sometimes.
    In the Formula SAE car they used mild steel tubing, that way it was easy to repair with a torch.
    • #17
      Here is a little trick to recover a bit more energy from the engine. Naturally you would point the exhaust out the back to gain the small amount of thrust it produces. That can be considerably augumented by using a simple arrangement to cause the exhaust to entrain additional air. The mass of the air entrained will more than double the thrust from the exhaust. It's the same principle that bypass jet engines use compared to pure jets.
      • #18
        Aluminum
        You may want to avoid aluminum in the frame and support members and opt for the carbon fiber material. The folks who made bicycle frames from aluminum tubing soon found that it hardens with age and after a few years, tend to fail at bad times.
        Jim (KB4IVH)
        Jim (KB4IVH)
        Only fools abuse their tools.
        • #19
          As others have stated I would consider the whole Smith lineup immediately, I've seen some specials if you buy them all at once:
          http://www.CarrollSmith.com/main.html
          I'm lucky to have Cerritos Community College relatively nearby, it has the only Community College based composites curriculum in California, I still have a sample of kevlar/aluminum honeycomb I stand on once in a while to amaze myself at how light/strong/stiff it is.
          In some situations steel can actually be the best material, especially if you are limited in cross sectional area and you have the time to machine the part and remove material in un-needed areas.
          I have some AZ61 magnesium it's easy to work with, but I don't know a cheap source.
          • #20
            Hey evan - i don't think 2.4 hp will generate a very noticeable amount of thrust...but do you have some dimensions for that? Looks like a fun little thing to whip up - i love finding tiny little projects to do on a lathe because the small projects are pretty much right at my skill level
            I like the idea of using some kind of composites except for the money involved and the difficulty of construction (that is difficulty in constructing a vehicle on the fly with composites - read w/o any plans )
            Also - i realize aluminumm will work harden but these frames won't be used more than two maybe three years anyway - thats only one to three races which means max of 75 miles on the frame. (thats with practice runs added in)
            • #21
              I wouldn't ignore it. A ten cubic inch engine running at 2000 rpm will be pumping about one half pound of air through it per minute. It isn't much thrust but in your application every tiny bit helps and it costs basically nothing to implement. If you can double that to one pound per minute out the back at maybe 100 mph exhaust velocity it isn't negligible.
              Dimensions? Nope, you will have to experiment.
              • #22
                Do not attempt to free up the exhaust.
                You want to keep as much heat in the engine as possible. A more restictive exhaust is the way to go.
                As far as an aluminum chassis goes. Look at how long a welded boat can last. They flex a bunch and seem to hold together.
                Using the proper alloy, a 5xxx series, and proper welding techniques your chassis would be strong enough.
                What do the rules say for materials?
                Gene
                • #23
                  Yep. The above trick will not only provide some back pressure but it also will use some of the exhaust heat to provide additional thrust. That idea is what made the P51 the fastest aircraft around in WWII. They used the waste heat from the radiator to overcome nearly all the cooling drag of the system by expanding the cooling air and expelling it out the restricted exit of the cooling shroud.
