Sparkplug extension at plug wire end
  • #31
    Reggie--I did think of that. I have four different kinds of welders here. Shouldn't be a big deal to make an extra deep socket from a couple of standard deep sockets.
    Design engineer
    Barrie, Ontario, Canada
    • #32
      Originally posted by reggie_obe View Post
      How will you install it? Do you have an extra deep socket to match the hex body of the plug which has a 1.6" extension glued to it?
      He could do like certain model fords or chebbies and just install it and then build the entire engine around it...
      • #33
        All you'll need is one standard socket and a piece of tubing of the appropriate length to place in between the drive end and the socket and a bandsaw to cut the socket.
        Did you get yours going yet, I haven't caught up to that thread ...yet.
        • #34
          Willy--I haven't started yet. I want to get the T-Head engine running perfectly before I move on to my next build.---Brian
          Design engineer
          • #35
            Sorry for the confusion Brian, I meant the bandsaw.
            • #36
              Okay, the game plan has changed a little bit. instead of having part of the brass turned to 1/16" diameter, it's a lot easier to drill a 1/16" hole completely thru the brass and silver solder a piece of 1/16" diameter cold rolled steel in there instead.
              Design engineer
              • #37
                So, here we have two sparkplugs extended 1". I'm not sure how this will work, but I will leave them to "set up" for 24 hours so the epoxy is totally cured, and then we'll see.
                Design engineer
                • #38
                  How about heat shrink tubing for an insulator?
                  Sole proprietor of Acme Buggy Whips Ltd.
                  Specialty products for beating dead horses.
                  • #39
                    Wood is an insulator.
                    Design engineer
                    • #40
                      More-or-less. When it is required to for-sure be an insulator, it has been vacuum-impregnated with wax, etc, as was done, I believe, to make "hot sticks" for linemen early last century.
                      At high voltages, it may be significantly less good as an insulator than you might think.
                      2730
                      • #41
                        Oak is quite porous lengthwise- you can actually blow through it and see bubbles come out in a glass of water. This means you can easily impregnate it with say a thin epoxy. You either apply vacuum to one end and suck the epoxy in until it's saturated, or rig up a small pressure vessel to one end of the oak 'stick', and force the epoxy in under pressure. That should provide a more stable piece of wood and increase its volts per mil at the same time, while leaving a natural oak look. You can buy a 'finishing resin' at a hobby shop- it's thin and has a reasonably long setting time.
                        Or, if you're even contemplating the idea of mixing resin, you could just roll yourself a fiberglass tube around the right sized mandrel or former. That'll give you a very high volts per mil rating.
                        • #42
                          For what it's worth---In this case wood is not a good enough insulator. I get zapped when just holding the wooden barrel. I had to try it and see for myself, but I would not recommend wood as an insulator.
                          Design engineer
                          • #43
                            Wood dried still has somewhere around 15% moisture content and is a very poor choice for high voltage insulating. Ignition coils normally start at about 10,000 volts and go up from there, HEI type ignitions around 45,000 volts. It takes a very good insulator at those kind of voltages. Now at 12V wood might be a good choice. Didn't you mention earlier that you had some corian? Corian would be a good choice.
                            Also, stay away from your old favorite JB Weld, that has metal filings in it !!
